? about 1999 honda accord
Old Aug 23, 2005 | 04:21 PM
markholder's Avatar
Default ? about 1999 honda accord
I just got a 99 accord with a 4 cyl. how do I tell if it is the better of the 2 that year?
Mostly I was wondering how easy is it to swap it with a v6 vtec?
Old Aug 23, 2005 | 05:50 PM
lowoctane's Avatar
Professional Dumbass
what model is your accord?..ex, lx, se? 2door - 4 door?
as far as better of that gen?..motor wise?...enterior?..special packages?..functions?..
to swap a V6?...i beleive the whole drivetrain and motor mounts and the whole base of how it sits its totally different, im not 100% sure, havent heard of anyone swaping a v6 into the 4cyl version, or took the time to look. i can take a look on thursday when i go back into work. but you never know if it uses the same mounts sense the bays are basically the same size. It's also something ive thought about looking into, so on thursday its something im going to look into, for me and you and anyone else that wants to know.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Aug 24, 2005 | 10:46 AM
markholder's Avatar
its power everything, 2 door i don't know what model, i just bought it for the gas for now but eventually i want to put a lil money into it
Old Aug 24, 2005 | 11:36 AM
Nata$'s Avatar
TR Balla Donor Supreme
I believe all of the 4cyl models are the same with that year. 150 HP, SOHC VTEC.
Old Aug 24, 2005 | 08:11 PM
wilp99's Avatar
the j30 block will not fit in a f23 accord cause the front frame is longer. besides its not worth it.. just drop in a h22, almost direct bolt in with alot less problems, and tons more options. i have a cl with a j30 in it so im not tryin to talk you out of doin it.
but if your insistant and do it i would suggest you doin a cl type s swap j32 260hp. or an odessy 3.5l j35 swap 265 hp
Wilson Motor Works Reliable Mobile mechanic WMW 4 LIFE
Old Aug 25, 2005 | 05:09 AM
markholder's Avatar
thanks for the help
