1990 Integra idles rought and hardly revs with WOT CEL#1 or 11 (not sure)
Old Aug 21, 2005 | 12:59 PM
97 Eclipse RST's Avatar
Default 1990 Integra idles rought and hardly revs with WOT CEL#1 or 11 (not sure)
My 1990 integra is not running right at all, it has no power, while sitting still it idles like crap, and when the throttle is opened to the max is sits at idle and will slowly creep to about 2000 rpms, then it takes right off, but while driving the car has no power an wont even get up and go to take off. Whats the problem? every now and then the check engine light comes on, and the ecu light flashes once fast, then once slow, and thats it, is that a CEL code 1 or 11?
Please help....
i can do 185mph with a 220mph tail wind
Old Aug 21, 2005 | 02:32 PM
Talon95's Avatar
Fakes the funk
If its coming up a code 1 then that means its your oxygen sensor, might wanna switch that out and see what happens. and by the way there is no code 11 so iono why its blinking that way,you sure its one slow and one fast?
Old Aug 21, 2005 | 03:16 PM
I was thinking 02 sensor as well, but got wondering i that would really make it idle rough and not want to rev
Old Aug 21, 2005 | 03:24 PM
TurboRotary's Avatar
Mazda > Honda
I dont think an 02 sensor would do that.. check and see if all of your vacuume lines are hooked up and in tact.
Honda Know It Alls Hater Crew Member #0000001
Old Aug 21, 2005 | 04:34 PM
methree's Avatar
loser x.x
also could be a code 10 and a code 1
i dont know why people dont take me seriously....now wheres my crack pipe
Old Aug 21, 2005 | 05:35 PM
Yellow Rocket's Avatar
The Big Diehl
fast blink is code one slow blink is code ten
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
Old Aug 21, 2005 | 05:47 PM
methree's Avatar
loser x.x
make sure button is on tight(screw inside of distributor.) also check for moisture. maybe vacuum lines also as stated by turborotary.
