Headwork
Old Aug 20, 2005 | 07:10 PM
skunked_rex's Avatar
window shopper
Default Headwork
What all can can you actually do to the head? As far as port and polish and all that. Every new peace. And multi angle valve jobs. How much does some of this shit typically run, because im fixing to get a gsr head for my ls crx to go ls vtec but want to build it up.
Old Aug 20, 2005 | 10:57 PM
TurboRotary's Avatar
Mazda > Honda
you better have at least an extra 1k laying around to do all of that.
Honda Know It Alls Hater Crew Member #0000001
Old Aug 21, 2005 | 03:45 AM
SoOo HigH's Avatar
i got a 95 gsr head for 450 complete except for a the intake camshaft or i can throw in a set of 96 gsr camshaft with skunk2 cam gear for 600
Old Aug 21, 2005 | 06:51 AM
freakasis's Avatar
oversized valves, dual springs, valve job, shave the head, port and polish, port match both manifolds, aftermarket cams, cam gears.
Old Aug 21, 2005 | 09:58 AM
BLK94EGCOUPE's Avatar
some nissan
I agree with turborotary theres a guy down the road from me that does all of that and ive looked into it and your looking at the least 1k,He told me the port and polish alone is $450.00.
Old Aug 21, 2005 | 10:12 AM
KJ's Avatar
KJ
bored at work
Only have people who specialize in Honda head porting port your honda head. These heads flow great from the factory and someone who is not experienced in porting these can just as easily make it flow worse than better.
Be careful with oversize valves in an all motor engine because the valves can actually hit each other with big cams. In general only run oversize valves in FI apps.
Alot of the flow gains that are achived from headwork on a typical street head is accomplished in the valve job. Alot of money can be saved by going with a nice performance valve job and not a full port and polish. Clearwater cylinder head does excellent valve jobs.
Old Renegade's Avatar
Cool Runnings
head work port polish vavles resurface all those good stuff for 1k more or less. parts to build up the head equal more $$$$$ out of your pocket. example header, intake mani, throttle body, cams, cam gears, dual valvesprings & retainers, valve guides, vavle stem seals and all the other head seals and or gaskets.
Old Aug 21, 2005 | 03:14 PM
integrex's Avatar
++1
Old Aug 21, 2005 | 04:36 PM
window shopper
Good thing i have all the time in the world to build this motor. i think im just gonna leave my crx ls and just buy a gsr head and block and then trick the fucvk out of the head and use the same turbo that im getting for my ls on the gsr. I CAN do that right?
My main goal for the next motor is about 350-375 hp without nitrous. im gonna do up the block too, but wanted to know how far im gonna need to go to support this application. thanks
Old Aug 21, 2005 | 05:03 PM
Mazda > Honda
yeah you can do that. For that much HP youre going to need to fully build it.
