ac compressor
Old Aug 16, 2005 | 11:21 AM
dmxplayainc21's Avatar
Default ac compressor
help pls the bolt that connect the ac line to the compressor broke into the compressor anyone has any idea of how to take the part that is broke off the compresso.....
Old Aug 17, 2005 | 09:42 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
get another compressor..................
tamparacing.com
Old Aug 17, 2005 | 10:49 AM
freakasis's Avatar
take it to a machine shop. they should be able to either pull it or drill and retap it for another size bolt. eitherway it would be cheaper than i new compressor.
Old Aug 17, 2005 | 10:59 AM
TSX24L's Avatar
your going to have to replace the ac comprssor. You can't tap redrill shit. You will get the shavings in the compressor. Anything forgein material that gets into inside is a replacement of the comprossor. Is so important that you make sure not to get anything inside.
How did you even manange to do this?
If you ac comprssor blew on you your going to have to replace everything. The lines EVERYTHING. Have someone that knows what there doing work on your car.
Old Aug 17, 2005 | 11:17 AM
i ma take it to a shop or some cuz a new compressor thats a lot of money ....
