DSM downpipe fit honda....??
You boys like Mexico!!!
on
i just got a hf manifold with about a 1" adapter plate and a stock 1g dsm turbo...my question is if a stock dsm down pipe will fit on the car with no problem or does it need to be modified...i plan on using a 16g turbo with the set up i plan on doing
Springhill
22" Nothing less
Springhill
22" Nothing less
on
whats so bad about mitsubishi turbos on a honda....the turbo i am using is a evo3 16g, i think it should be more then enough for the number i want
Springhill
22" Nothing less
Springhill
22" Nothing less
Thats what my Talon's fixing to get installed also.Triple G on here laid down over 400awhp with room to play on his vr4 galant.Post on how it works out.
on
yeah its not going to be done for a while but im doing this size turbo on a small 1.6 sohc vtec motor (z6) and im pretty sure ill be happy with the turn out...i figured with a 16g a stock down pipe would work pretty good
Springhill
22" Nothing less
Springhill
22" Nothing less
Guest
Posts: n/a
Mitsu turbos have NEVER worked properly IMHO on a Honda. I've seen about 10 of them running around. From t25's to 20G's. they never produce the power that a DSM does. Even at higher boost settings. For some reason DSM (mitsu) turbos do not like Honda heads. I cannot say for lack of proof why. it's just how it works. Look at the GReedy kits. Even at 15psi, they do NOT break 300whp.
260whp from an 18G at 11psi on a stock B16 just isn't something I like to see.
