ok I'm lost - obd1 code 22 *read*
Ok car is throwing a code 22 - VTEC pressure valve
I've already tried/done the following:
checked oil level
I've done all my voltage checks, continuity checks, resistance checks for the switch, the solenoid and the wires in the harness involving the switch and solenoid etc.
I swapped out a good known pressure switch and a good known ECU.
I checked oil pressure and it was within vehicle specifications.
I jumped the Vtec solenoid and yes, it clicks.
I pulled apart the solenoid and the screen is fine, everything is clean. the plunger operates properly
checked for oil leaks. there is a small oil leak at the oil pan for the turbo return line, but it's minor and def not big enough to cause a pressure loss.
The only thing i have yet to try is swap a good known vtec solenoid assembly.
If it's not that I'm lost.
anyone have any other ideas?
checked oil level
Contact me:
Adam B.
Cell: (727) 742-0633
Contact me:
Adam B.
IT has to be something in the wiring , in between the pressure switch and the ecu...im guessing something shorting out..... That is honestly the only thing that i can think of...but you said u checked for contunity , so i guess that isnt right...hmmmmmmm
~jake
~jake
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
And dude , what happen to the eg hatch with the ek front end? that shit was tight, i remeber when you met me in plant city and i bought that po6 from you.....or maybe you bought the ecu from me ...
that thing was clean
_Jake D
_Jake D
Switch and Valve two seperate things, Swap the Assymbly. You prolly have a clog you cant check Pressure without the engine running and in VTEC if you have Trash in the valve or a Bad Seal/o-ring you throw a code. get a New Assy.
cold-beer - hey bro, ya i remember meeting you, I was omw to orlando and met you and your buddy at arby's
I ended up having to sell it to pay off some bills.
I actually found it at a local junk yard like a week ago. the guy i sold it to wrecked it bad lol.
now it's a 92 hatch with a crushed as hell front end conversion.
owel way to hijack my own thread lol
Contact me:
Adam B.
Contact me:
Adam B.
If you checked the wires and the computer, the onlything left is the entire solenoide. swap that one with a good known one. I might have one that I can let u borrow to try it. But its been in my closet for a while so im not sure if it is good anymore. If you can get your hands on 1 that is known to be good, that would be the best thing to do. You also might wanna just put a Vtec light on that SOHC since Vtec sometimes is hard to feel or hear on a SOHC. PM me if you need this solenied that I have or if you need help puting the Vtec light on it.
Swapped in a good known solenoid today and still getting the code 22.
the light comes on when i hold the RPM's anywhere above 5k (where i have vtec set)
i can hold it right below 5k and the light won't come on, but as soon as it tries to engage vtec... it dosen't, and the light comes on.
i dunno what else now except the light never came on before tuning.
if anyone has a p28 socketed and wants to help. i have 2 other test to make but need another socketed p28.
if anyone can assist me lmk!!
thanks
adam
thanks
adam
Contact me:
Adam B.
Contact me:
Adam B.
