oil pump 90 integra
Old Aug 4, 2005 | 06:04 AM
quietflight6787's Avatar
Default oil pump 90 integra
ok i need to know how the heck you change an oil pump on a 90 ls integra... help me out.. im new to this stuff!
Old Aug 4, 2005 | 06:55 AM
if anyone can give me a good idea on how to change the oil pump or how much work it is that would be awesome...
Old Aug 4, 2005 | 07:28 AM
freakasis's Avatar
well you have to remove the front drivers wheel, crank pully(hardest part), then the timing cover, the timing belt, about 6 10mm bolts (dont forget the ones on the oil pan) then it just comes off. make sure you use gasket maker when you put it back together, and dont lose the oring that seals it in the back. have fun
