Eg brake lights wont turn off
as the title says the lights wont turn off at all unlees the battery dies or i dissconnect the battery....what can i do to fix it or make the light go off for now
thanks
thanks
Springhill
22" Nothing less
Springhill
22" Nothing less
there is a little rubber plug underneath your dash on the pedal assembly it is what releases and pushes the brake switch to turn them off and on. when you depress the pedal. it is a common problem with the older cars. It just dries up and breaks apart..you probabl have some little pieces on your floor board..check and see.
the piece usually costs like a buck from Honda.
just follow the brake pedal all the way up till you see it seperate. you will find that the brake pedal hits a lil black button that is the brake censor you will need to replace it b/c it is bad if you are cheap and want good results just super glue a nickel in between the sencor and the pedal works great. I have never had a problem since if you need help lmk i will come help ya fix it for free.
i always put a bolt and nut there
Great accomplishment only comes with great risk. I’ll accept the crippling, gut wrenching disappointment of risking all, and failing, but only by putting my whole heart and soul, my whole being into something, will I have the chance to walk among the stars.
Those who risk nothing, those who live their lives in fear, will never have that chance.
Failure is not a sin. It’s being too afraid to even try, that is a sin.
