need your opinion
Old Jul 29, 2005 | 07:49 AM
ChrisMonsod's Avatar
Drives a cowboy corvette
Default need your opinion
well as some of you know i am in the process of boosting my h22 accord
but i ran in to some problems.
when the turbo is on the manifold it hits the front motor mount
and i might lose my ac due to the ac line being in the way.
- should i grind the mount down til it fits?
- should i get a smaller turbo?
- should i sell the whole kit ?
- should i sell my car ?
- should i sell em both ?
- should i start a new project? "i always wanted a teg"
WTF should i do ..
Old Jul 29, 2005 | 08:09 AM
silvspeed's Avatar
Doing Work.
if the turbo kit fits a 92-96 lude sell it to me......actually id grind some of the front mount off then just polyurethane the rest of the mounts...heck just eliminate the front mount and poly the rest
Old Jul 29, 2005 | 08:31 AM
just looked @ it again there are 4 mounts that hold up the motor ..
tow side mounts one rear and one front .. is it a bad idea to elimnate that front mount ?
Old Jul 29, 2005 | 01:46 PM
There is no right or wrong way to fabricate something......
Any pics of how close the fit is?
Sight unseen, my 2cents says grind away just a little of the front mount.
.....and screw on a short piece of A/C hose to the existing one to make it longer, so you can re-route it.
To make a new front mount easier to wedge into my car past the header,
it was pretty easy to grind off 1/4" from each side of the 4 inch wide base.........
and the mount almost FELL into place!
I also shortened the bolt sticking out the top of the mount, so I don't have to jack up the motor so high to swap it out next time it goes bad.
WTF should i do ..
Old Jul 29, 2005 | 01:49 PM
Blueboost's Avatar
towards antisocial
Yes. If anything just grind it down, and use stiffer mounts all around.
Old Jul 29, 2005 | 02:23 PM
- civic TypeR B16b-'s Avatar
JDM TILL I DIE.
well i have always had hatchbacks especially efs with b16 b18 and the h22 swap and when you swap you dont use the front mount so i would do away with it just get some good hassport side and rear mounts and you will be fine. Post pics of the clearence issue.
Old Jul 29, 2005 | 10:35 PM
silvspeed's Avatar
Doing Work.
yea most def. just do away with the front mount its not necessary....look at most or i think all of the hasport mounts none are the front just 2 tranny and the driver side engine mount.....just go get some polyurethane or window weld same ish and fill up the other 3 and you'll be good to go
