my "long awaited" engine
Old Jul 27, 2005 | 04:15 PM
na200whp's Avatar
Powered by BOOST
when you say stock bottom end do you mean pistons as well? due to small valve reliefs in the ls pistons running typeR cams and a vtec head cut 40 thou. you may be tight on your piston - valve clearence. just a heads up.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Jul 27, 2005 | 04:40 PM
KJ's Avatar
KJ
bored at work
Yeah I was going to mention the piston to valve stuff also. I'd pull the head off and clay check it if you didn't originally. I know of a couple of people who tapped valves with that same setup and the head wasn't milled.
Old Jul 27, 2005 | 05:04 PM
WagonMaster's Avatar
vtec yo!
all stock no tapping and i have revved over 8000 already"the bottom end was not torn apart-no break in" thanks for the input though!
Old Jul 27, 2005 | 05:08 PM
na200whp's Avatar
Powered by BOOST
what are your cam gears set at?
K series on crack
S D M
Old Jul 27, 2005 | 05:23 PM
vtec yo!
0 and 0
Old Jul 27, 2005 | 06:20 PM
BUDO's Avatar
The Sick No Longer Died
looks good dude. everyone knows 4door vtec is the only way to ride
Old Jul 27, 2005 | 06:30 PM
  #17 (permalink)
CRXkid24's Avatar
uh oh
ahahaha nice setup george. thing rides nice.
my car gets mad after 5,500 rpm!
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old Jul 27, 2005 | 06:32 PM
  #18 (permalink)
na200whp's Avatar
Powered by BOOST
when you mill the head it causes your cam timming to retard . im guessing that is what is saving your valves. if you tune your car and advance the cams it will become an issue.
K series on crack
S D M
Old Jul 27, 2005 | 06:35 PM
  #19 (permalink)
vtec yo!
thanks na200whp i want to change the pistons in the future but for know i have to much invested ,how much cam timing would i have to do with the s/c you think????
Old Jul 27, 2005 | 07:09 PM
  #20 (permalink)
na200whp's Avatar
Powered by BOOST
i would leave it if it is running fine. the only real way to be sure how much you can adjust is by pulling the head and claying it.
K series on crack
S D M
