h22 1992 cx question
I figured out the vss, tps, and the Map, Heres my question, On my rex I used my 89 rex si map, and everything was fine, What should i use on this particular deal, Do i use the one on the cx, or find a h22 one?
Anyone have a spare H22 rear motor mount bracket? And dose anyone know what the evap wire color cose id on a cx model? Compared to the h22 one that is on the front side of the intake manifold. ?
Thanks Cole
Thanks Cole
And When It Rains.. It Pours..
Roughneck Refab .Inc
u should be able to retain and use the h22 map sensor that is on the throttle body, i am unsure if the cx has the map sensor on the firewall or the throttle body. Even so the plug should just plug right into the h22 map sensor. As for the wire issue i dont know much about the evap wire color, sorry.
-Braxton
-Braxton
hey cole i need the code for tyour dist??is it a TD60U or what??? theres one on ebay i found i just wanna make sure its identical to yours.call me
DOHC VTEC 5 lug 94 accord
legend calipers,h23 tranny
ill checkit outtonight, I just got a cratemtr. 5.7l R series for my 2500hd, Oh ya im gonna have some funtonight. Wish me luck, Later Cole
1994 Firebird 3.4L V6
Favorite Mod: 1993 Z28 Drivetrain
good luck with the swap if i was there i would help you out.just let me know on the distributor by tomorrow night i found one local and i need to make sure itll work.later man
