Cam seal replacement...
Old Jul 6, 2005 | 10:16 AM
GOTTI's Avatar
OEM Parts Specialist
Default Cam seal replacement...
DO you have to remove the cam to replace the cam seal on the cam seal that always leaks on the B18 (the front right side next to the distributor)
Old Jul 6, 2005 | 10:40 AM
KJ's Avatar
KJ
bored at work
no but you need to break loose all the cam bolts (in sequence) and remove the oil spray rail and cam cap. Put everything back together in sequence and torqued down to spec. Might as well replace the distributor o-ring too.
Old Jul 6, 2005 | 11:48 AM
rangcrx's Avatar
engine building &best
sounds like he has a ls tho,if so no you dont have to you can just remove that last cap lift it up and replace
i love AUTOZONE
Old Jul 6, 2005 | 12:55 PM
Sabotage's Avatar
slash
+1....good luck!
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old Jul 6, 2005 | 01:09 PM
The Spectacle's Avatar
Spent more money than you
I need to do this soon as well. somebody remind me.
Racing Integration
LHT Performance
My tuner is named Alpha
Old Jul 6, 2005 | 01:13 PM
Sabotage's Avatar
slash
hey spectacle, dont forget to do yours soon!
reminded, my job is done!
meows meows
Old Jul 6, 2005 | 01:21 PM
Racing Integration
LHT Performance
