Can Anyone Help Me Please
Old Jul 5, 2005 | 10:09 AM
vtectuner2204's Avatar
Default Can Anyone Help Me Please
I recently did a b16g2 JDM swap into my 1996 civic EX and I did a complete swap motor trans ECU did not do the wiring harnes used a jumper wire.
I now have a check engine light on and it says that all the sensors inside the distributor are giving bad readings. I checked the resistance of all the sensors and they all check out fine. It is also saying that it can not find the o2 sensor. but it is wired correct too. Vtec will not engage with the check engine light on and some times it will cut out the ignition at 4000 rpms. If anyone has had this problem your help would be appreciated. I am open to all suggestions please.
thanks for your time.
Old Jul 5, 2005 | 10:11 AM
Default Also
I used my old o2 sensors. I got a new map sensor (firewall mounted) also got AEM intake and there is no place to put IAT sensor (intake air temp)
Old Jul 5, 2005 | 10:43 AM
Carlos's Avatar
**International Baller**
explain.
Old Jul 5, 2005 | 10:53 AM
Default harness
http://www.jkobd.com/
This is what it is
