electrical madness
Old Jul 1, 2005 | 10:26 PM
LS4drCivic's Avatar
Is back in action!
Default electrical madness
i got a crx and the underdash harness was hacked so i replaced it, well now im not getting any power to the ECU, ive rechecked everything atleast 10 times and everything is hooked up correctly. my main relay is bad but i only thought that controlled the fuel pump, im wondering if that will keep the ecu from getting power, the only other thing im thinking is the only thing in the car that i havnt replaced is the engine bay fuse box, so im thinking maybe that could be bad for some reason, any help is greatly appreciated
Is finally 4dr pimpin again
Rollings not racing either go from a dig or go home
Old Jul 1, 2005 | 11:10 PM
LS4drCivic's Avatar
Is back in action!
ok i put the fuse box outta my other car in it and its still the same problem, so its either the main relay or the computer itself is bad, but i doubt the computer is bad,
Old Jul 1, 2005 | 11:17 PM
rangcrx's Avatar
engine building &best
check your underdash fushbox i think it is the first fush i pulled mine out and forgot to put itback it killed me
i love AUTOZONE
Old Jul 1, 2005 | 11:34 PM
LS4drCivic's Avatar
Is back in action!
ok ill check it out, thanx
Old Jul 1, 2005 | 11:54 PM
LS4drCivic's Avatar
Is back in action!
lol, i think that was the problem, but to top the night off my battery is dead so imma give it up for tonight and start back in the morning, well later in the morning, i keep forgetting its almost 4am
Old Jul 2, 2005 | 08:52 AM
LS4drCivic's Avatar
Is back in action!
ok the fuses werent the problem either, im goin to test the ECU in my friends DA and then try to get another main relay, anyone else got an idea what it could be???
Old Jul 2, 2005 | 07:25 PM
LS4drCivic's Avatar
Is back in action!
found the problem it was a bad ground, now to top everything off its throwing code 9 which is #1 CYP, so now i need to get a new distributor, lemme know if anyone has one for a decent price
Old Jul 2, 2005 | 11:05 PM
rangcrx's Avatar
dx or si?
i love AUTOZONE
Old Jul 3, 2005 | 08:10 AM
TSX24L's Avatar
how do you know its the distributor and not the wiring?
Old Jul 4, 2005 | 05:32 PM
LS4drCivic's Avatar
Is back in action!
the car is an HF but the previous owner did a hack job on the wiring so i replaced everything, only problem is that it was all DX wiring, its converted right and everything, i got everything worked out now,
