car idles too high
my car idles at 2500 what could the problem be? i have a b16 motor changed the intake manifold gasket it dropped from 3000 to 2500 changed the throttle body gasket it shot up to 3000 again try to adjust with the screw on the throttle body no good
That might point the way as to what needs to be changed back.
that rpm is high sounds like you forgot to hook up eather your brakebooster hose or pcv hose
i love AUTOZONE
i love AUTOZONE
I had that same problem in my integra, I changes EVERYTHING out it could possibly be, and it ended up being a cracked manifold. I've never heard of a manifold cracking but mine did. Your best bet to start to hunt the problem down is to Loosen the throttle cable, see if that helps. then check for any vacuum leaks, of course thats going to make it idle high as hell. the only other thing i could tell you is what i had to do. I actually ended up having to make a cardboard throttle body gaskets that blocked off the iacv. Good luck -Ben
