Tire size difference(pics)
I have tried many different tire combos to see what works. Here are what a 195/55/15, 235/60/15 and 26x10x15 slick look next to each other. The 235/60/15 measures 26x8 and the 195/55/15 is about 23x7.
GOOD STUFF RON! i wanted to change over to a larger drag radial such as something in the 235 range but im looking to see if anyone makes a 235/55 but i think no one does.
i knew you had a set, so how did they work for you as far a being able to be driven on, street wise
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
i believe those are some old skool hard to find enkeis if im correct, 15 inch and kinda hard to find, its just like an hx wheel only bigger
owner/operator
owner/operator
Here is how the the 195's compare to the slicks. I drove the car around the nieghborhood with the 195's on to test out my tranny and i must say it is an experience with hardly no rubber.
I'm probably going to use them on my Crx when it's done since they are not wide enough for the tire size i want to run on my civic.
Originally Posted by Teamcalloway03
What kinda rims are those they look like bigger Hx,s........I want a set
so thats how you do it...........
you dont have to buy any lawn equipment, you gots no grass to cut!!!
so thats where all the money comes from, i need to do that, or get some astro turf!!!! all this st augustine cost me an arm and a leg, here in alabama!!!!!! but i had to have it, my little piece of florida
owner/operator
owner/operator
