teg wont start: help a loser out.
first time ever today. batt is fine, turned over. I guess the first thing is to check for spark, whats the best way to go about this on a teg? I think it may be the distributer, what should i be looking for with that? Spanks.
best way to check for a spark is hold a metal flathead put it in the sparkplug wire and turn the car over if you get zapped move on to the next one,or just find a used plug pull out all the wires and put just the plug and stick it close to the bodyy of the car then turn it over
i love AUTOZONE
i love AUTOZONE
check for gas, spark, then all your grounds , check cam angle sensor make sure everything around the distributor is connected, we need more info on whats going on.... Does the starter engage? Do you hear the fuel pump prime itself when u turn the key to ACC? Are all your fuses in the engine bay ok?
Any electrical/voice/data work needed or questions please feel free to PM me.
Wiring is no hobby, call an Electrician.
myspace page
myspace page
This would be funny to watch.
where are you located at? if around me i will check it out for nothing..i am sure i can figure it out..pm me
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
