b18c1 owners i need help!!!
Old Jun 8, 2005 | 02:38 PM
gsrcivic92's Avatar
OG MEMBER
Default b18c1 owners i need help!!!
have u guys experienced hard shifting ruff shifting or grinding gears? please let me know whats up? i read a thread i forgot where but it say that on the b18c1 original clutch the disk messes up and causes ruff shifting,please post here the problems and results..i dont wanna start buying stuff for no reasons...thanks
Old Jun 8, 2005 | 03:33 PM
crazyhatch's Avatar
someone's been in here b4
does it do it in every gear or just some ,and what rpm range does it do it
Old Jun 8, 2005 | 05:21 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
first step and cheapest is always to check and/or flush tranny fluid...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jun 8, 2005 | 05:55 PM
Sabotage's Avatar
slash
i was having a hard time shifting and it was shifting rough right before my clutch went out. i tried adjusting the pedal and i checked the fluid and it looked brand new so i figured i needed a new clutch. when i looked at the disc, one of the springs was all fucked up so yeah, that was it. put then new clutch kit in and everything was fine.
good luck!
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old Jun 8, 2005 | 06:22 PM
NChatch's Avatar
i stepped on my weiner!
something after you check the fluid would be the shifter "balls" there are two ball bearing type balls that the shift rod rides on, going into the tranny, they are pressured by a spring, sometimes the springs wear out causing the shift rod to have a little play, up and down and shifts get sloppy and dont want to go.
also my shift rod was bent, not that i shift my car hard or anything( i would NEVER do that:sarcasm)
or last but not leats synchros, go to gearspeed on the internet and order them, they are pretty cheap
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jun 8, 2005 | 06:36 PM
crazyhatch's Avatar
[QUOTE=NChatch]something after you check the fluid would be the shifter "balls" there are two ball bearing type balls that the shift rod rides on, going into the tranny, they are pressured by a spring, sometimes the springs wear out causing the shift rod to have a little play, up and down and shifts get sloppy and dont want to go.
they are called detent balls ,and they should not cause a hard shift, or grind if the spring was worn ,thay rearly would go bad
Old Jun 8, 2005 | 11:44 PM
Retired Ricer...
I bent my shift linkage too Rough shifts owned that bitch
Old Jun 9, 2005 | 04:07 AM
NChatch's Avatar
[QUOTE=crazyhatch]
well mine went bad in my JDm gsR, and they seemed to be causing an issue with shifting, so i replaced them and all the above named parts, well jason did, and my tranny shifts perfect
owner/operator
Old Jun 9, 2005 | 08:08 AM
crazyhatch's Avatar
gsrcivic92 can we have more info
Old Jun 9, 2005 | 08:48 AM
gsrcivic92's Avatar
OG MEMBER
yup thats exactly what i heard thanks bro...and thanks to everyone that replyed to this i really appreciate it guys...
