new set-up is complete
Old Jun 8, 2005 | 09:29 AM
uncle bens wildrice's Avatar
i heard vtech
Default new set-up is complete
my new setup is now complete
Block:
90 b18a1
Bored out .25 over
Block was decked 5 Thousandths
.25 Over JDM ITR Pistions
Shotpeened LS Rods
ARP rod bolts
ARP head studs
b16 water pump
gsr oil pump
GSR timing belt
JE Piston rings
LS VTEC Cometic head gasket
Head:
92 JDM b16a SiR II, with new valve steam seals.
3 Angle Valve Job
Full Race Port and Polish
Shaved 30 thousandths
Crower valve springs and retainers
Buddy Club spec III cams
Skunk2 intake manifold ported and polished
STR 65mm throttle body
Ferrea .5mm oversized valves
Other Goodies:
JDM dc sports 4-1 header
ES Oval 2.5" Inch Exhaust
Low Cashe chipped pr3 ecu (no governor, no rev limiter)
Apexi VAFC (still needs to be tuned)
AEM Fuel Rail
RC 270 injecters
Holley Fuel Pressure Regulator
Bronze STR cam gears
Place racing mount kit
Hasport shift linkage
Energy suspension bushing kit
Tokico Blues Shocks
Transmission:
s1 close ratio - mint, no grinds
Exedy Stage 2 Clutch
Exedy 12lb lightened flywheel
it is just one engine lab and cfm stop away from being back on the road, plus there are a couple things not on the list i cant give it all away. i hope to put down some decent power.
Old Jun 8, 2005 | 09:34 AM
Suspect's Avatar
Certified since '85
Good luck with the setup man.....................So that means we should see you out again soon right??
TR Hydroponics Abuser #36329
J a s o0o n: i need to get piss ass shit face fuck bag bitch ass drunk god damn
Old Jun 8, 2005 | 09:37 AM
BigBodySmith's Avatar
Retired Street Racer
sounds really nice, good luck with the setup, is it going into the car in your sig???
My Old Honda
Old Jun 8, 2005 | 09:43 AM
Drivermod03's Avatar
Hope this one treats you better than the last one...And hope to see you out in your own car soon...Not the Eclipse
Old Jun 8, 2005 | 09:45 AM
PantySniffer's Avatar
grippin grain
Nice....Definatly post up #'s when you get them...
Obsession is a word used by the lazy to describe the dedicated.
GO GATORS
Old Jun 8, 2005 | 09:50 AM
dansr20's Avatar
Damn, for a while it seemed like youd never be back out, but i guess i shouldnt be saying shit because im kinda in the same boat. Sounds like its gona be sick. Dont forget to get some deasent tires or all the power wount mean shit.
Old Jun 8, 2005 | 09:52 AM
i heard vtech
yes i will be back out running the streets again, there are a few people that i want to met up with and hit up a few races
Jaso0on's Avatar
Is now ballin!
Finally got it done? Sounds nice...
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Jun 8, 2005 | 09:53 AM
i heard vtech
yeah i wont ever get those bfg drag radials ever again those things sucked with the last setup
Old Jun 8, 2005 | 09:56 AM
i heard vtech
hoping to get this thing over to tampa next week or week after to get some numbers, it will definetly put down higher numbers then the last setup
