what springs do you spring around with??
What part of "These springs will put it on it's nuts" didn't you understand? Oh, and don't pull these ones out with a dremel or plasma cutter,
you might be able to make a couple bucks off em. I know a certain ricer in a black hatch that needs the shocks desperately if you're losing those too.
Originally Posted by SiPunk
how about coilovers? do they ride as comfortable as the springs??? any recomendations?
Proven Power Dyno Services
A++
Built not Bought
A++Built not Bought
tien ss or tien basic you will love them for all of time
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
tokico blues suck my asshole. no thanks.
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
too much work! i would rather just put something i know will clear them and just start driving.... may b looking in to those coilovers though
thanx for the idea mr.honda, but i just wanna drive my oil leaking ass civic
Originally Posted by senor honda
The way I would check to see if the tires would clear the fenders,
would be
1.put 2 X 4's under the car at the height the body would be riding.
2.Jack up and remove the "springs only" and re-assemble front suspension without springs.
3.lower the car down until it sits on the 2 X 4's at the height it would be driven, and look to see if the tires will clear the fenders.
.........what do you think?-Bob
would be
*Edit*
As a matter of fact, I'm thinking that you might be better off going with either a Honda wheel or aftermarket 15/16 with the appropriate offset. See if you can trade those expensive 17's for something more practical? Those 17's are going to cause you to spend more money than it's worth IMO. And if you want to do a 17 right, you need bigger brakes, camber kit, taller ride height, etc... Replacement tires and rotors will cost more.
P.S. you'll be hard pressed to find a better ride quality than what you have if you like lower than stock. If you must keep those wheels, OmniPowerUSA.com get the omni-man coilover package with camber kit and keep the blues. That's going to be the most economical way IMO. Ride quality will depend on your choice of spring rate.
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
AIM: TurboedTrip
Well, you could either go around your elbow to get to your A$$hole, or measure the offset and account for the overall inflated tire width.
*Edit*
*Edit*
i hate when u make sence! arrghhhh.... im thinking about it.... i mean loosing the 17's dont kno yet but ill c
