Hydrolic transmission/ int. med. shaft. . .
94-01 Integra 5 speed, or 99-00 Civic Si.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
transmission side all 90-01 integra are the same and as for drivers side you can use auto or 5speed thay are both the same on 90-93 and 94-01 integra.only the halfshaft is different on 5speed/auto if you useing the halfshaft that is coming with the tranny((it has 1 male side((tranny side))and one female side then you use 94-01 integra..i recomend if the crx is lowered Use the axels with ABS thay are about 1/2"longer and help camber
i love AUTOZONE
i love AUTOZONE
I tried to use a drivers side axle from an auto once, and it didnt work... Bastards at Napa gave me the wrong one, so 2 hours later when I finally took it back and got the right one, it went in with no problems....
strang cause i dont think it ask when you buy it at like autozone or anything cause thay are the same,it only aks with or without abs but i will check more
i love AUTOZONE
i love AUTOZONE
so use the half shaft and axles from a 90up integra? with abs to lengthen and help camber? Sound right? I just want to know what setup do use. I need a good discription cause I wount have alot of time to go back and fourth to the parts store. I have to do this swap in one day.
How would buying abs axles help camber??? If you have abs, buy abs axles, if you dont have it, dont.... only difference is the abs ring on the axle, which once popped off, makes the axle the same as the non abs...
well good news is auto and manuel are the same just tested them and yes abs are a bit longer so when your car is lowered or at least for mine i tried both non and with..and for some reason the abs being that bit long are not as tight but this i guess is my own thing
i love AUTOZONE
i love AUTOZONE
