Where do blue springs come from?
Old Jun 3, 2005 | 02:03 AM
Default Where do blue springs come from?
Came across some blue springs for my Accord.
As an experiment I put on the fronts so far, but the
car no longer steers like a Buick as they did with
modified OEM springs and KYB gas shocks.
I also put some Honda shocks back on.
The blue springs set the front end down lower that the "street
height" of my modified OEM springs and are definitely stiffer.
I reset the alignment, and still need to make some
parts to increase my castor.
The front crossmember bolts are 3.5" off the ground
and are clearing the speed tables where I live.
So my question for you folks with more Honda experience
than me: What is the most likely source of color-coded
blue Honda springs? I thought I would drive 'em for a few days
before checking the spring rates.
Old Jun 3, 2005 | 04:51 AM
Punkinterviews's Avatar
Chavez Motorsports
The color has nothing to do with drop/spring rate. But it has everything to do with manufacturing
Different companies use different colors. IE Neuspeed springs are yellow, Intrax and green and so on.
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Jun 3, 2005 | 05:15 AM
NChatch's Avatar
i stepped on my weiner!
sprint springs-usually blue
suspension techniques-sometimes blue as well
but punkinterviews is correct, it has nothing to do with spring rate or ride height
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jun 3, 2005 | 07:29 AM
The Spectacle's Avatar
Spent more money than you
Originally Posted by fadedSTi
tokico's possibly
+1
Racing Integration
LHT Performance
My tuner is named Alpha
Old Jun 3, 2005 | 10:45 AM
lowoctane's Avatar
Professional Dumbass
yeah most likey sprint...and i think the blues are like a 3 inch drop.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Jun 4, 2005 | 05:54 AM
darkjungle565's Avatar
look at my ball!
yep my sprints are blue and pretty low
Old Jun 5, 2005 | 06:09 AM
DANGERANGER's Avatar
Shop Bitch
Smurfs!
Old Jun 6, 2005 | 02:35 PM
You might be right. The drop *IS* about 3". Thanks.
Can you give me a website to read up on these springs?
