dual point to multi point injection
Old May 29, 2005 | 11:52 AM
91_CRX_Tuner's Avatar
Bad Ass White Girl
Default dual point to multi point injection
i have a '91 hf crx. what do i need to do to convert a dual point injection harness to a multi point injection harness? i went from a 1.5 non vtec to a 1.6 sohc vtec. i have an si underdash harness and an injector resistor box and an si distributor.
Max A.K.A. Speedy
Miss New Bimmer
Old May 30, 2005 | 02:38 PM
agent93's Avatar
hell, if you have the si underdash, get an si motor harness too so you have to do no electrical work im going to assume you already have the manifold and injectors and whatnot. just install the new disty on your motor, there should be a plug (if you decide to get a si motor harness) to plug into the resistor box. see, you cant just plug an si engine harness into your car because stuff just doesnt match up with the hf cabin harness. but get an si engine harness to make things really easy. the disty basically pops in, and has an "idiot proof" way of going into your head so you cant install it backwards. should be plug and play with the new harness. they are cheap and easy to find too. so i say do that, good luck
Old May 30, 2005 | 02:48 PM
60-1EK's Avatar
Engineer at the source
You have a HF?
JESUS SAVES
9.69@151 Street Car
JKOBD
Old May 30, 2005 | 02:57 PM
MrLHT's Avatar
John @ LHT Performance
An HF is Multi point. ( 4 Injectors)
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
Old May 30, 2005 | 04:59 PM
agent93's Avatar
i was thinking std. my bad
