Overheating
Anyone have any idea why my car is overheating? I have a 90 si hb with b16. Looked down at gauges yesterday and temp. was rising fast so i pulled over and the radiator overflow tank was overflowing. Wasnt a stuck gauge...this thing was hot. Also, the fan WAS working. So i checked my hoses and they were in pretty bad shape but didnt look like they were leakin. So I took out radiator , did entire coolant flush 50/50 and replaced the 2 hoses. Going to do thermostat today maybe its stuck closed??? Any help would be appriciated. Thanks. JT
Cell: # 813-817-5377
Email: fbjJESSE@yahoo.com
Official TR "Old Skool EF" Member #074
Cell: # 813-817-5377Email: fbjJESSE@yahoo.com
hopefully that will solve your problem, if not, id say water pump, or maybe even headgasket
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
all i can think of is the thermostat.... try that and it should clear right up...
RIP Kevin "Slo_Si" You'll be missed by everyone who knew you my nigga.... I'll see you soon man...
ok put in new thermo. and seems to be better, not overheating but the temp. is going up higher then normal (3/4). Not sure what the deal is but will check water pump and seals.
take out the thermostat and heat some water up to 180 the thermostat should open if it's working, if you don't have a temp gauge to check water temp, just boil water cause that 212 and if it doesn't open then you know it's bad. i've done it before adn know this way works.
that's president hussein obama to you :gordy:
i had the EXACT same problem a while back and i had to buy a new radiator and fan , and now its fixed..i got a radiator and fan for under 100 dollars on ebay..and they look nice, and work real good.
IF IT HAS TITS OR TIRES YOUR GONNA HAVE PROBLEMS
oh ya and the reason for me having to get a new radiator was because my radiator was clogged, and also cause my condensor fan was not coming on...but i've also heard if u were driving your car pretty hard its most likely a water pump..but that's just what i hear..i dont know for sure..but hopefully its just as simple as it being your thermostat..good luck
