help with b16, error code 15 and 20
15
Ignition Output Signal
missing or defective ignition output signal
20
Electrical Load Detector
defective circuit or unplugged / defective sensor
im more concerned about 15 because maybe thats whats causing my car not to have spark and no fuel pressure. what do i need to look at?
please help, im a noob on b16s
the crx has a brand new distributor
20
bump! please help!
those 2 codes no one can answer with out looking at your car im sorry..i dont think you will get the answer you seek with out someone knowing about hondas can look it over
i love AUTOZONE
i love AUTOZONE
wait are you useing a pm6 ecu?
i love AUTOZONE
i love AUTOZONE
oh gosh thanks!!! ill check the car out this coming friday to see if i can get it to run.
yes, im using a pm6 ecu, i actually got a stock pm6 and the zdyne one. ill let you all know what happens this cmoing friday!
thanks to EP1491 and AKA5000!
well if your useing a pm6 there are you codes right there.well at least your code 20 is from useing that ecu
i love AUTOZONE
i love AUTOZONE
so what does that mean? i have to change my ecu? the car ran fine with the zdyne ecu. but rightnow, with a pm6 and a zdyne ecu its giving me both codes. the weird thing is that sometimes code 20 will go away if i take off the battery and put it back in.
looks like its gonna be a fun friday for me. jesus, this is gonna suck.
btw, we should make a thread where we state what problems we had with our swaps and a quick solution on how they fixed the problem... what you all think
I have a b16 in my crx and I have a pr3 ecu. You can use a pw0 ecu also. not sure about your zdyne. as for the thread about "swap horror stories", you were already in it complaining that no one would help you.
