whici pins for ctr pistons on ls rods?
Old May 10, 2005 | 05:04 PM
freakasis's Avatar
Default which pins for ctr pistons on ls rods?
which wrist pins are long enough to fit the ctr pistons? they cant look up the ctrs at the dealership. i can get itr gsr ls b16....which ones will work best?
Old May 10, 2005 | 07:21 PM
1fasthatch's Avatar
Traction Problems
I'm pretty sure any OEM B series piston wrist pin will work!!!
www.artofspeedproductions.com
Old May 10, 2005 | 07:31 PM
freakasis's Avatar
i thaught so too but the Ls ones that i have just seem too short.
Old May 10, 2005 | 07:37 PM
1fasthatch's Avatar
Traction Problems
the only thing you need to do is have the rods machined
If I'm worng someone correct me
Old May 10, 2005 | 08:19 PM
freakasis's Avatar
i know i need to have the rods machined, i just thaught the pins looked a bit too short.
Old May 11, 2005 | 12:13 AM
rangcrx's Avatar
engine building &best
all the pins are the same thay only look longer in the pistons cause the way typeRs are cut thay will all work the same if your use ctr i would say go with the cromoly thay are lighter and will last and are perfect you need part 10426 http://probeindustries.com/Wrist_Pin...=Chromoly+Race
i love AUTOZONE
Old May 11, 2005 | 11:46 AM
freakasis's Avatar
ok thanks
Old May 11, 2005 | 01:13 PM
mtber's Avatar
Do not machine the rods. Mill the piston 1mm on each side so that the ls rod fits in the piston. Make sure to balance the pistons.
Old May 11, 2005 | 01:24 PM
TSX24L's Avatar
except pr3's. Which fit perfect.
Old May 11, 2005 | 01:27 PM
mtber's Avatar
You listed that you were using ctr pistons
