what pistons should i use for an h22 turbo
Old May 5, 2005 | 04:57 AM
NChatch's Avatar
i stepped on my weiner!
big misconception that because the H22 is a closed deck, and that it is strong, but if you really look most of your H22 set ups blow up way before B series do, h22s have been proven to die off early, closed deck or not.
best pistons IMO endyne roller waves!, good chunk of change but they sure can take some abuse!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old May 5, 2005 | 07:36 AM
juiced2ndgenteg's Avatar
h22's have fiber reinforced cylinder walls, very similar to the f20c. It would need to be sleeved to use aftermaket pistons.
Old May 5, 2005 | 08:04 AM
accord95's Avatar
USMC
Originally Posted by Frankie Figs
Do you mean WONT need to be sleeved? Earlier H's are closed deck blocks. B series motors should be sleeved for turbo IMO The way you said it sounded like B series dont need to be sleeved
it doesnt matter if its closed deck or not, the stock sleeves are made from FRM and i believe the wiescos are the only pistons that are coated and safe to run on the stock sleeves. but, there are still many people out there that are having problems with the wiescos on stock sleeves, but there are also plenty of people without problems. just to be safe, i would sleeve the motor. better to be safe than sorry.
also, do a search because we had a huge thread about this same subject already, also search on honda-tech.com because they have had many threads on the same subject.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old May 5, 2005 | 08:20 AM
accord95's Avatar
USMC
click here
https://www.tamparacing.com/forums/s...ht=h22+pistons
___________________
Old May 5, 2005 | 08:35 AM
accord95's Avatar
USMC
also check out this thread, lots of arguing about h22 pistons
https://www.tamparacing.com/forums/s...d.php?t=185040
___________________
Old May 5, 2005 | 08:36 AM
accord95's Avatar
USMC
Originally Posted by SEEKERone
My previous post which would have contradicted this has now been deleted...further investigation shows that i didn't have full knowledge of which i spoke and i bow before your superior wisdom...
thank you for teaching me today
yep, the h22a1 is closed deck, but that doesnt really have much to do with it, FRM is FRM. all H series motors, S2K motors and late model NSK motors have fiber reinforcedn metal sleeves aka FRM. FRM was used to keep the block size down, while providing structural rigidity to the cylinder sleeves since they were so close together. .
wiseco has developed a forged piston to run in FRM applications by using a coating on the ring lands and piston skirting BUT it doesnt seem to be working
read about the problems here with the wiseco's, starts off good but towards the end of the thread it gets ugly. seems they arent lasting.
http://www.honda-tech.com/zerothread?id=416069
read this too.
http://www.honda-tech.com/zerothread?id=834071
___________________
Cronic
Feb 21, 2005 10:04 AM
Underground Performance
Power Adders
Sep 24, 2002 10:36 AM
