ctr pistons in an ls block???
ok, i am kinda new to the honda world. i have an ob1 ls in an eg hatch. i need a new block. also have plans for ls/vtec in the future. and since i have some ctr pistons i was planning on putting them in it. can this be done??? the compression height of the pistons is the same and the thickness of the wrist pins in the same...so i would assume so. but the ls rods will not fit into the piston they are too wide. does anyone know if i needs new rods? or what???
the pistons or rods need to be machined to accept the piston other than that they fit perfectly without any other modifications. and if youre planning on running big cams id clay the motor for piston to valve clearance
+1 as well, roninb18c5 is going to be selling his set up soon, already machined perfectly and what not you should pm him. he is a great and very trust worthy seller. however don't expect to be able to lowball, this shit isn't cheap to build.
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
well were they cold pressed or hot pressed out of the ls pistons
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
