Ignition Problems
Old May 1, 2005 | 02:45 PM
eldominicat43's Avatar
Default Ignition Problems
i just lowered my compression from 10.6 to 9.6. now that i did that the car does not want to turn on. i check the coil (good). i got distributor cap and rotor. i checked for spark to the head and it is also good. everything is on timing (timing belt, etc). i wanted to ask if i need more of an ignition spark to turn it on the the since it has lower compression. if not, any suggestions. thanks.
Old May 1, 2005 | 02:51 PM
BitbyStreetRacin's Avatar
once your bit, your done.
Im guessing your running a hi-boost head gasket? The car is turning over, but it wont fire? Do you have fuel pressure, compression, etc.?
Old May 1, 2005 | 02:56 PM
yes i do
Old May 1, 2005 | 02:57 PM
it dont want to fire
Old May 1, 2005 | 04:22 PM
Old May 1, 2005 | 07:00 PM
mtber's Avatar
So your saying you have fuel & spark but it doesnt start ?
Try a compression test ?
Old May 1, 2005 | 07:13 PM
iskate2's Avatar
wears black
see if there are any codes in the computer. obd I or II?
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
Old May 2, 2005 | 01:01 AM
pheobo's Avatar
Boom Chackalacka
+1
You sure you have fuel and spark?
200+ MPH Club
1000+ HP Club
Old May 2, 2005 | 07:31 AM
If really do have fuel pressure, then the injectors arent opening up.
Old May 2, 2005 | 09:48 AM
freakasis's Avatar
try turning it over a few times and then smell the spark plug...see if it smells of fuel. if it does then there is obviously no spark. if it doesnt smell of fuel. its prolly your injectors or no fuel is getting to the injectors.
