help
Old Apr 25, 2005 | 03:39 PM
92hatchGSR's Avatar
sohc sshhhhh
Default help
do i need to change my valve springs in my gsr to put itr cams in it
Old Apr 25, 2005 | 03:54 PM
95gainfla's Avatar
smokes weed...everyday.
most companies recommend it(valve springs and retainers as well)
Old Apr 25, 2005 | 06:49 PM
rangcrx's Avatar
engine building &best
just buy some inner springs from acura or find a set of inner springs
i love AUTOZONE
Old Apr 25, 2005 | 07:16 PM
incrxheaven's Avatar
whuuuuusaaaaaaaaah
i heard u can get away with stock valve train as long as u run a mild cam. when u start getting higher lift. thats when u need different springs so they dont bind up.
Old Apr 25, 2005 | 07:20 PM
1fasthatch's Avatar
Traction Problems
If you don't want to get crazy just get some portflow inners and use itr outers
www.artofspeedproductions.com
Old Apr 25, 2005 | 08:08 PM
rangcrx's Avatar
thats true but remeber the itr/ctr is 1mm 1.1mm higher at high rpm that matters that extra pressure will help floting to be safe do it i just sold my itrsprings but im sure you can find them almost as cheap
i love AUTOZONE
Old Apr 26, 2005 | 02:39 PM
00TEGLS's Avatar
yes most definately
