ls vtec idle
Old Apr 24, 2005 | 07:22 AM
nefesto's Avatar
Your Mother's Best Friend
Default ls vtec idle
i got my ls vtec running last night... only thing it idles at 2k sometimes 2.5k. any suggestions what to look for...im using a pr3 head and an early model jdm intake manifold(has the pgm-fi plate on it). i did try the idle screw on the throttle body and its turn all the way down. check the throttle body and it is not sticking... any suggestions?
Old Apr 24, 2005 | 07:43 AM
rangcrx's Avatar
engine building &best
does it drop at all or you always around 2K even when it warms up?
i love AUTOZONE
Old Apr 24, 2005 | 08:06 AM
91Crx but i heard vtec's Avatar
All Socoms CAMOPIMPIN
check for a vaccume leak , i would check the oil catch can if u even run it check to see if connected or all of ur hoses
DONT SLEEP's penis tastes soooooo good
Old Apr 24, 2005 | 08:27 AM
nefesto's Avatar
the idle doesnt drop...it stay constant even after its warmed up
Old Apr 24, 2005 | 08:43 AM
rangcrx's Avatar
then its a leak somewhere i would try your brake booster or get a small part of a box and cover up your Tb hole((DO NOT USE YOUR HAND))and see if the idel drop way low if not there maybe your problem
i love AUTOZONE
Old Apr 24, 2005 | 10:15 AM
mtber's Avatar
Sounds like your leaking vacuum via a intake manifold gasket or throttle body gasket etc.
Old Apr 24, 2005 | 05:43 PM
Jay's Avatar
Jay
Janky
my ls vtec has the oddest idle in the world haven figured it out some times it idles at 2k some times it idles lower at like 1k some times it moves back and forth like 100 - 300k its weird.
i dont have any leaks etc not sure what it is so i said fuck it lol
Aim: o JankyJ o
http://jankycrew.com
Old Apr 24, 2005 | 08:43 PM
CivicStylez's Avatar
Yea theres definately a vacuum leask, check the hoses that run from the intake manifold to the charcoal cannester, might be those ones.
Old Apr 26, 2005 | 10:41 AM
EP1491's Avatar
Boared Over
This may help
http://www.ef-honda.com/ben/Badidle.php
sebastian
Mar 11, 2004 08:17 PM
kwikdelsol93
Oct 2, 2003 09:51 AM
webdog
Mar 9, 2001 01:50 PM
