Need help installing cf hood...
Old Apr 23, 2005 | 07:49 PM
icegsr's Avatar
Default Need help installing cf hood...
The damn hood won't lock. Please give me advice on installing hood pins or advice on making the hood lock. I have an 93 hatchback. Thanks guys.
Old Apr 23, 2005 | 08:15 PM
mtber's Avatar
There are 3 10mm hood latch bolts you can adjust...
Old Apr 23, 2005 | 08:20 PM
Trip's Avatar
Dramatic Lemur
Well, you can either attempt to lower your latch (Tuff work) or you can cut the hook on the hood and go with some good pins. However, I caution you to keep a watchful eye on the pins, bad stuff happens when they aren't latched and you take off for a ride.
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Old Apr 24, 2005 | 06:12 AM
icegsr's Avatar
I've already adjusted the 3 10mm bolts and adjusting the rubber standoffs but it still won't lock. I think my only option is to install hood pins.
Old Apr 24, 2005 | 06:36 AM
Juicy_J's Avatar
clownin since 81'
which hood are you using? what brand?
Any electrical/voice/data work needed or questions please feel free to PM me.
Wiring is no hobby, call an Electrician.
myspace page
Old Apr 28, 2005 | 05:12 PM
Outkasted24's Avatar
** I ♥ Old Skool **
If the hood is sitting perfectly even and it still won't latch, Bust out a dremmel with grinding tool and shave down the coating on the latch.
Sometimes aftermarket latches are to thick.
Once you get it to finally catch, Make sure you paint the latch to keep from rusting.
I had this same problem with all 3 of my Fiber Images hoods.
My Flickr
slam.poke.drop.tuck.dope
Old Apr 29, 2005 | 06:17 PM
SleepingB18's Avatar
just mike.
Id go with the pins. It would be more safe and you can get them anywhere from Redneck trailor on MLK or Landig Tractor off of causeway. Safety first!!
