100 and 110 Octane in TR Area
Old Apr 25, 2005 | 09:23 AM
24-7's Avatar
Civic Racing eXperiment
Originally Posted by MrLHT
Where ?
That mechanic shop that has a whole buch of busted cars out front, across from the welding supply place.
Old Apr 25, 2005 | 05:31 PM
MrLHT's Avatar
John @ LHT Performance
George ,,,,He has race gas ?
www.lhtperformance.net.
727 344 1800
*Turbocharging* Engine building* Tuning *Intercooler piping*exhausts* headers* clutches ,fabrication and much more
13 years in the same location.
** HONDATA Authorized Dealer+ Tuner **
01 Type R-647whp street car w' AC - Cover of turbo magazine Feb 2008
01 K20a INSIGHT - Cover of Honda Tuning magazine June 2008
2011 KR-Z K20 powered CR-Z -Cover of Honda Tuning magazine April 2011
Old Apr 25, 2005 | 05:50 PM
Juicy_J's Avatar
clownin since 81'
What are the benefits of running higher octane? Any noticable gains in power?
Any electrical/voice/data work needed or questions please feel free to PM me.
Wiring is no hobby, call an Electrician.
myspace page
Old Apr 25, 2005 | 06:52 PM
MrLHT's Avatar
Higher octane has higher resistance to detination. Meaning more cylinder pressure ( boost , static compression , more timming etc.)
Example:
Nothing is set in stone , but you could increase your total timming when running higher octane, which will increase HP.
On a 4 cylinder , I use 400 whp as a safe limit of pump (93 oct) gas, many have made more power but 93 is a little unstable with that kind of cylinder pressure.At that point 100 or higher is a good choice.
Every tuner will have what they feel safe with HP v Octane.
Hope this helps.
727 344 1800
Old Apr 25, 2005 | 07:18 PM
mtber's Avatar
Example:
Hope this helps.
Additionally, in some instances depending on the fuel, engine setup etc you "could" run leaner conditions when running higher octane fuel.
Whp is not a good refference of when to run higher octane fuel because you have to factor for compression ratio & charge density etc.
It is always good to run the same "brand" fuel that your vehicle was originally tuned on due to the fact that fuels with the same octane rating from different manufacturers tend to burn differently & at times have different maximum brake torque levels.
Old Apr 26, 2005 | 03:25 AM
MrLHT's Avatar
[QUOTE=mtber]Additionally, in some instances depending on the fuel, engine setup etc you "could" run leaner conditions when running higher octane fuel.
I would never run an engine leaner with higher octane, more timming yes but not leaner. Some cases leaner will make more power , but also turns things to a melted mess.
QUOTHE = mtber ] Whp is not a good refference of when to run higher octane fuel because you have to factor for compression ratio & charge density etc.
I said I use it as a " safe point " , on Honda-tech they make 9000 hp on 87 octane ..... Every tuner has there own way. Alot depends on the motor , I have made over 400 on Hess 93 oct , but I wouldn't recomend it.
727 344 1800
Old Apr 26, 2005 | 06:37 AM
  #17 (permalink)
mtber's Avatar
I quote my self.
"depending on the fuel" i.e. meth, alcohol etc.
Old Apr 26, 2005 | 12:41 PM
  #18 (permalink)
MrLHT's Avatar
True ,,,,
727 344 1800
4.6Power
Nov 11, 2002 06:45 PM
