timing belt
timing belt
I just put a new timing belt in my b16, I turned the car on and it runs like shit. I pulled the spark plugs and found oil on all 4 of them. I hope I didnt f it up.
Oil on the plugs isn't necesarily a bad thing, it depends on where the oil is. If it's on the actual firing surface you could have big problems. A little oil on the neck/porcelain or threads is indicative of bad valve cover gaskets.
Did you check timing?
Originally Posted by mdiym13
its were the threads of the spark plug is, i dont understand why it would do that. my valve cover gasket is a little messed up.
engine building &best
on
heheheh when you put the valve cover back on did you put back on the sparkplug tubeseals?
i love AUTOZONE
i love AUTOZONE
+1 on the tube seals i was having the same problem but i picked up a complete valve cover gasket set from napa and havent had problems yet
(\___/)
(")__(") This is Bunny. Copy and paste bunny into your signature to help him gain world domination
(\___/)
After you set timing did you roll the motor over twice and recheck?
