2 cylinders not firing
Old Mar 31, 2005 | 06:44 PM
aka5000's Avatar
Default 2 cylinders not firing
got a b16 obd0. I have a problem with two cylinders not firing. Ive double checked the firing pattern, I have spark to all four plugs. I could not smell fuel in the two cylinders when checking for spark. Im using my old 90 crx si harness that ran my car fine before the swap. Waht do you think I should do?
Old Apr 1, 2005 | 07:27 PM
KJ's Avatar
KJ
bored at work
On the two cylinders not running check that 12V is going to the striped wire. If it has 12V then hook up a "noid light" and see if the ecu is driving the grounds correctly. If both of those check out try a new injector or try moving the injectors you have around to different cylinders and see if thew dead cylinders move with the injectors. If the dead cylinders stay put run a compression and possibly a leakdown test.
Good luck.
BTW a noid light is a LED light bulb run between the two injector clip terminals. These can be bought or made.
Old Apr 5, 2005 | 06:34 AM
aka5000's Avatar
did all of the above and it came down to the old "tap-tap" test... I had my g-friend turn it over and hold an idle while on two cyl's. Tapped on the #2 injector an it fired, tapped on #3 and it fired. Had her take her foot off the gas and it idles by itself. it idles kinda low, but its workable... Thanks guys
aka5000
Mar 31, 2005 09:07 AM
neon-joe
Apr 2, 2003 06:42 AM
hockeyfreak007
Mar 27, 2003 05:46 AM
Als SS
War Stories
27
Feb 20, 2001 11:49 AM
