Gsr Or B16 Head
it all depends, a B16 is very very similar to the ITR in ways of design, shape, volume, and flow, they are almost identical.
the gsR is slightly different from both of them, it will yield you more power directly after the swap because the gsR yields higher compression. but i have always heard of people saying they dont flow as much.
there is of course contradicting sites with different flow numbers for both of the heads, anywhere from RLS,portflow,alaniz,JG
hope this helps
hope this helps
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
my comment on a ls block with b16 head equaling a ls vtec is when it is correctly built is that I <3 the torque it puts out.
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
if you just plop the head on, you won't get that big of a gain in power. i say go balls to the wall w/ the b16, cams, cam gears, valvetrain, portpolish...and make some real power.
I would use a b16 head. I feel they make more power than the gsr. also LS pistons have smaller valve pockets on the intake side. the LS intake valve is 2mm smaller than the vtec valve. this leads to valve clearence problems if stock cams are not used. using b16a pistons in the LS block work VERY nicely. no mods needed. they drop rite in.
here is a link with some info on that swap
http://www.phatwhippincrx.20m.com/custom4.html
