Uberdata + Apexi safc??????
Old Mar 29, 2005 | 08:07 PM
00ACCORD's Avatar
SPEED DEMON
Default Uberdata + Apexi safc??????
Can you run a apexi safc with uberdata?? Any suggestions would help. Thanks
Old Mar 29, 2005 | 08:12 PM
60-1EK's Avatar
Engineer at the source
Sure you can. You could also run Hondata with an AEM setup too.
JESUS SAVES
9.69@151 Street Car
JKOBD
rebels's Avatar
Shaved Accord
if you are using uberdata, basically there is no point in running a safc. it would defeat the purpose, plus uberdata is hella better than just running the safc.
Adam
University of South Florida - Graduate School
Old Mar 29, 2005 | 08:50 PM
Miles's Avatar
It's a wooden pickle.
so if i wired 3 ecus together, i could run uberdata, hondata, and crome?!?!?! it's the perfect engine management solution!!!!!!!
Old Mar 29, 2005 | 08:53 PM
mtber's Avatar
Check this small tutorial I wrote:
http://www.phearable.net/tech/efibeginnerguide.html
It may help your understanding.
Old Mar 30, 2005 | 04:24 AM
NChatch's Avatar
i stepped on my weiner!
i always had to keep my AFC with my uberdata set up because i had uberdata a long time ago and we had trouble with it idleing 450cc injectors on the tunes we were using, so i had to keep it there for minor adjustments, which you could make with it.
but be careful, if you pull fuel from the AFC it seems to bump timing up and if you add fuel it seems to pull timing, IF you go past a certain parameter in the AFC.
but all in all it seemed like the uberdata just narrowed the tune really close for me and i just tweaked it with the AFC. but now there are people out there who can get uberdata alot cleaner and more efficient than i did a tear or so ago
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 30, 2005 | 08:21 AM
mtber's Avatar
Trouble idlling 450s ? wow
Anyhow, you have your answer. Don't use an afc if your setup is tuned on crome or uberdata unless you want to have a useless display box.
Old Mar 30, 2005 | 11:53 AM
NChatch's Avatar
yeah it had trouble idleing my 450s but likei said it was a long time ago, long long time ago
owner/operator
Old Mar 30, 2005 | 11:57 AM
jsimon9631's Avatar
You Love UBERDATA!
Green Eyed Princess Lover
Mexican Jedi Pimp
NA is BEST
Old Mar 30, 2005 | 04:05 PM
superhatch69's Avatar
im idleing 660 cc injectors on my civic
