Problem with The RSX Suspension wise.
Ok so last night had to remove the manifold, dp and turbo to swap out my dp.
In the process had to drop the subframe from the chassis and the front and rear motor mounts.
we accidentally jacked the car up with the strut bar removed and the struts fell and the axles came loose inside the boot. we snapped them back on and we did everything else but when i drive now the car shakes in low speed , in fact any speed.
any idea on what it could be?
Green Eyed Princess Lover
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
Not sure on Hondas/Acuras,but my car did this,regreased the axles=problem solved
Hopefully its nothing bad,i wanna see this thing tuned and hauling more ass!
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
gonna double check all those things you guys mention since we THOUGHT we did but you are right could of been a bit off.
Mexican Jedi Pimp
NA is BEST
Mexican Jedi Pimp
NA is BEST
Axels came apart in the boot...
Check those.... subframe check too
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Drewpw4ng
Apr 21, 2004 03:21 PM
