Changing the guts out of distributors . .
Old Mar 18, 2005 | 06:50 PM
TSX24L's Avatar
Default Changing the guts out of distributors . .
I need a obdo distributor for my y8 head. But is obd0 electronics. I have 1 Ls obd2 distributor , 1 b16 distributor and 1 99 y5 distributor from the hx civic. I also have my crx si distributor that has been hacked into when running the msd actavtor (vtec on the switch) the wire that you cut to run to the msd switch was cut down to far to repair in the dizzy. Its the yellow wire(maybe a ground?)
Has anyone tried to interchange any of these? Maybe just cut the obd0 dizzy plugs and use the wires from the obd2 dizzy.
Or does anyone want to trade any of the above distributors for a obd 0 dizzy?
Old Mar 18, 2005 | 06:57 PM
ekdriven's Avatar
moved back home ;x
danm you got alota parts.. good luck bro.
90 Talon TSi [sold]
00 DC2 gsr [sold]
97 EK [current] slow
-dominick
Old Mar 19, 2005 | 07:25 AM
KJ's Avatar
KJ
bored at work
You need to use the obd0 dizzy and internal components like the trigger wheels and pickups. You can switch out the internal wiring of an obd0 dizzy pretty easy. The obd2 stuff won't fit perfect. Find another non-dpfi obd0 dizzy and swap the internal wiring, done this before.
Old Mar 20, 2005 | 07:10 AM
DOHC16CRX's Avatar
CARPET GUY
you can not use a obd1 or obd2 dizzy with a obd0 ecu..it will not read from the distributor.if the wire you are saying is to short on the crx dizzy you have then just solder and heat shrink a new wire on it..
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Mar 21, 2005 | 08:19 AM
SEEKERone's Avatar
Trialed for Treason
Use the OBD0 D series distributor as is...it will bolt on to a Y8 head no problem.<unlike on a Z6 head which requires modification>
You need one from either a 89-91 Civic Si 88-91 CRX Si or HF. DX will not work with MPFI.
As stated before...the OBO0 ecu needs the OBO0 distributor.
Liar, you couldn't cut me deeper with a knife if you tried
Old Mar 21, 2005 | 10:01 AM
CRXwitnoVTEC's Avatar
"...I just don't like the structure that is my everyday life, it's alomost permanent like nothing ever changes and when it does its for the worse."
-myself
[EKU] Elite Kill Unit... SOCOM Soulja... Leader... <ECO>
TR.com's pushing company's work van to the MAX crew member #001
Left Hand Drive JDM = Thumbs Way Down...
