crx rear disc help
i took the whole rear suspension off a 93 del sol(had good rotors and pads
and put it on the crx dx. used the del sol master cylinder and proportional valve(or however u say it) and bled all four brakes with the aircompressor bleeder. No lines are leaking as far as i can see. The pedal feels good, fairly hard, and the pedal does not creep down at all, ever, but the cars braking is worse than when it had drums on the back. I cannot come to a complete stop without pumping the brakes atleast twice. What am i doing wrong? Can anyone give me suggestions on how to fix this?
vacum lines hooked up correctly? mess around with the line going to the master cylinder
Any electrical/voice/data work needed or questions please feel free to PM me.
Wiring is no hobby, call an Electrician.
myspace page
myspace page
it makes a difference where there hooked up on the mainfold
myspace page
myspace page
as far as i know the lines should be hooked up correctly, i have never had a problem with them before..i have the stock b16a manifold, but Its pouring down rain outside now so i cant go look at the manifold but ill double check that and the master cylinder asap. thanks
try moving them around, i had this same problem when i was running a zc , same symptoms, i moved the vacum line around that attach to the master cylinder and after alomst wrecking a few times i figured it out, hope this helps
btw rain sucks
btw rain sucks
myspace page
myspace page
moving it around on the manifold , i believe the master cylinder line is one of the biggest vacum lines on the manifold, so swap it with one on the manifold, thats a similar size in diameter
myspace page
myspace page
ok.. as soon as this rain slows up just enough ill run out with a flash light..im almost to the point of taking it to my mechanic
It seems to be a pretty simple swap, not sure where i went wrong. thanks
try looking under on the right side, this is where it was on my Zc, I hope it similar to the b16 mani
myspace page
myspace page
