Shift rod oil seal replacement?
Old Mar 14, 2005 | 10:09 PM
Spence's Avatar
"TEAM WHITEY"
Default Shift rod oil seal replacement?
Hey guys how hard is it to replace your shift rod oil seal? I just put a swap in and it seems to be leak there
Thanks
Spencer
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old Mar 15, 2005 | 05:16 AM
GOTTI's Avatar
OEM Parts Specialist
spence my car seems like it leaks there also and it isn't. I have replaced my shift rod oil seal and i still have a leaking issue. I guess its good to change it anyway. You might have a leak between the casing of the tranny. Double check.
But the seal is easy to replace. Just drop the linkage a and take out the old seal and then gently tap the new one into place.
type-j-spec
Mar 6, 2005 03:35 PM
Cronic
Nov 7, 2003 03:04 PM
Cronic
Aug 26, 2003 10:12 AM
