oil light
Old Mar 11, 2005 | 12:46 PM
alri0085's Avatar
Scuderia ALRI
Default oil light
The oil light keeps coming on when I drive my crx. What could cause it to light up. The oil level is not low because I changed the oil today. I don't take my car over 2500 RPMs, the idles at like 500RPMs, could this be the reason?
The engine is a d16a1 with forged everything and I just installed comp cams with ferrera springs on a ported and polished head. Where's the oil pressure sensor? maybe it's loose or dirty.
Old Mar 11, 2005 | 01:18 PM
CiViCBoY's Avatar
Lamer
Sensor should be on the back of the block like above the oil filter
Old Mar 11, 2005 | 02:18 PM
mtber's Avatar
You actually may have low oil pressure....
Get an oil pressure guage.
Old Mar 11, 2005 | 02:32 PM
Nandosol's Avatar
Garage Slut
Could be bad oil pump, or you could be losing oil pressure somewhere
Old Mar 11, 2005 | 10:08 PM
Janky99's Avatar
Honda Guru
Make sure your oil pickup isnt clogged, very common if you previously spun a bearing. -Ben
Old Mar 12, 2005 | 06:12 AM
alri0085's Avatar
Scuderia ALRI
I changed the oil and put full synthetic only instead, the oil light doesn't light up anymore. maybe be I should not use cheap oil on a built motor
Old Mar 12, 2005 | 07:12 AM
lead's Avatar
I'm Awesome
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Mar 12, 2005 | 03:21 PM
1stGen7's Avatar
layin frame for life
Says in the haynes manual that if your idle is to low the oil light could come on I dunno?
Old Mar 12, 2005 | 04:24 PM
alri0085's Avatar
Scuderia ALRI
Yeah, I fixed that by advancing the ignition timing.
type-j-spec
Mar 6, 2005 03:35 PM
Cronic
Nov 7, 2003 03:04 PM
Cronic
Aug 26, 2003 10:12 AM
JTP
Aug 6, 2003 08:18 PM
