D16A6 or D16Z6 waterpump?
Old Mar 8, 2005 | 07:57 AM
Sharpview's Avatar
hyperbola
Default D16A6 or D16Z6 waterpump?
D16A6 block and D16Z6 head w/ d16Z6 timing belt. . . .
Do I use the A6 or Z6 waterpump?
Rockin imports since the 80's . . . . .
EF/EG & OTHER parts for sale
Old Mar 8, 2005 | 08:30 AM
Sharpview's Avatar
hyperbola
Originally Posted by Cronic
I believe you use the water pump designed for the block. .
cool, i was just worried about the teeth being the same on the pump as the belt . . .
Old Mar 8, 2005 | 09:55 AM
chet's Avatar
All Aboard
Use the A6 water pump, it will work fine.
Old Mar 8, 2005 | 11:01 AM
NChatch's Avatar
i stepped on my weiner!
i do as well recommend using the vtec oil pump.
funny i have read about and built a few ls/vtec style motors and they always talk about "this belt goes with this" and "that belt goes with that" funnything is have never followed that rule on any build yet, i mean hell all aftermarket cam gears say "B" series, hardly any say nonvtec or vtec right?!?!?!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 8, 2005 | 01:11 PM
boostedb16a3's Avatar
Equal Opportunity Hater
[QUOTE=Cronic]I believe you use the water pump designed for the block. Might be a good idea to use the VTEC oil pump though.[/QUOTE
I took a trip down to the local honda dealership, Apparently the y7 block and the y8 block utilize the same oil pump. I do not know about any of ther other D series block, but I found that interesting. The pump is only $85 new.
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Originally Posted by JAVIELITO
limpio as fukk
