Honda Prelude jdm h22 Distributor Cap help
What distributor cap fits a 93 prelude JDM H22? Because the regular h22 doesn't fit. I think its because of the internal or external coil difference.
Originally Posted by EludeR
You sure you got a dist cap off of a USDM OBD-I H22A ? Sometimes the parts stores will give you the wrong part ... take your original cap off and take it with you .
I was told that a 93 civic would work but I was just trying to find out before I ordered off the internet.
I'am not sure the civic distributor cap will work ... but i do know that alot of the guts are the same among honda distributors . Just get a distributor cap for a 94 h22a prelude ... you will be fine . They don't cost that much at local parts stores ... so i don't see why you should order it off the net and sit their and wait for it to arrive.
jdm is internal coil; usdm is external coil.
you can do what i did, and go to automotive engineering and they have a few h22 caps; and get an external msd coil and wire it up yourself. perfect fix.
member no. 191
member no. 191
94 civic si cap is the right cap. The coil if you ever need one is also a 94 civic si.
Gracie Barra Clearwater
I used a D16Z6 cap/rotor for my h22. Fits great.
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
another thing, if your actual distributor goes out, you can only use a JDM h22 distributor, none of the others will fit. its much easier to switch to external coil with the MSD system, thats what i just did two weeks ago.
TR happily married crew-member #2
___________________
___________________
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
