can i do this?
Old Feb 17, 2005 | 11:39 AM
geoff's Avatar
2fast4u
Default can i do this?
i wanna swap a 98 d16y8 sohc vtec motor into my 94 hatch. i was wandering if i could use my motor mounts on my car now and if not wich ones do i need? also i can use my wiring harness right? how will i make it work? thanx
Old Feb 18, 2005 | 02:45 PM
Hybrid_eg's Avatar
i like the blue ones
if you want to stay obd 1, you need a P28 ECU and a 92-95 cx/vx/dx distributor. everything else should hook up without problems. as for the mounts, SHOULD work, but i'm not sure. i'll look into it though..........i have nothing else to do.
Shut yo ass up nugguh..
ReginaVagina
Old Feb 18, 2005 | 03:34 PM
NChatch's Avatar
i stepped on my weiner!
actually you should use your wiring harness, or one from the vtec models of that year like an si or ex, use the obdI vtec distributor and a vtec ecu, if you use the non vtec dizzy you have to do some converting on it, and it always ends up not being right.
you mounts depending on what model yo uhave will work, the main drivers mount may have to be removed from you motor and attached to the new motor, when i mean mount i mean the bracket between the timing belt and corresponding mount from your chassis
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Feb 18, 2005 | 03:41 PM
Hybrid_eg's Avatar
z6 dist doesn't bolt to the y8 head w/o mods. only cx/vx/dx does...
ReginaVagina
Old Feb 20, 2005 | 11:02 PM
geoff's Avatar
2fast4u
so which dizzy do i use? the z6 or the cx,dx,lx,vx ?
Old Feb 21, 2005 | 03:22 AM
Hybrid_eg's Avatar
don't the guts out of a z6 dist. fit into a cx, vx, dx dist? look here (been busy all wekend for once) http://www.honda-tech.com
ReginaVagina
Old Feb 21, 2005 | 06:11 AM
geoff's Avatar
2fast4u
any more info cuz im still confused. some say to use a 92-95 sohc dizzy and ecu and others say to use the y8 dizzy and ecu. then i got guys sayin to use the y8 dizzy and p28 ecu. wtf? i know i need the obdII to obdI conversion harness, so what else? i heard that the 92-95 vtec dizzy wont even bolt on right. some one who has actually swaped a d16y8 motor into a 92-95 civic non-vtec help.thanx
