throttle body spacer
Old Feb 10, 2005 | 06:36 PM
oldandbusted's Avatar
Default throttle body spacer
by putting a throttle body spacer on will that drop my idle any im just looking for 400-500 rpm drop any tricks to get it to go down?
Old Feb 10, 2005 | 07:25 PM
iskate2's Avatar
wears black
where is your idle at now?
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
Old Feb 10, 2005 | 07:33 PM
around 2300 but motor sounds like it has an idle limiter strange but seems what it is but when i let the clutch out and rpm drop a bit it goes away
Old Feb 10, 2005 | 07:37 PM
warpd's Avatar
HAve you messed with your IACV before? Doing stuff like that isnt good. you should try to find out what the problem is and fix it the proper way. Not trying to be a dick or anything. Does the idle go down after warm-up? Any idle jumping?
Old Feb 10, 2005 | 07:39 PM
no just steady 2300 nothing else is wrong i have had people look at it so now im just looking for away to bring it down couple hundred rpm
Old Feb 10, 2005 | 08:06 PM
mtber's Avatar
home depot washers work great... just kidding...
If your idle is that high, there is an issue with your setup somewhere... sounds like a vacuum leak.
Old Feb 11, 2005 | 03:42 AM
iskate2's Avatar
wears black
+1 on the vacuum leak- buy some "brake-clean", spray it around the engine bay, and see if the idle picks up even more when you spray in different areas. do small areas at a time- under the intake mani, behind the throttle body, and check the intake mani. gasket.
Old Feb 11, 2005 | 03:33 PM
na200whp's Avatar
Powered by BOOST
check your throttle cable . it might be to tight. i dont feel its a vacume leak because if the throttle plate is closed the ecu would be going into injector . i think the throttle plate are cracked so the ecm sees it as pushing the gas.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Feb 12, 2005 | 10:25 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
ive looked at this car b4 and checked the throttle cable and its fine as far as vaccum leaks i couldnt find any this car is possessed call me when u have a chance 813 299 3801
tamparacing.com
Old Feb 16, 2005 | 11:56 AM
mranlet's Avatar
eats gunpowder
Does the idle stay at 2300 or does it surge up and down?
What work has been done to the engine?
BTTS, STFU&D
