CYL sensor question?? Really need help
Old Feb 10, 2005 | 10:13 AM
alri0085's Avatar
Scuderia ALRI
Default CYL sensor question?? Really need help
My stock SOHC ECU requires that the CYL sensor have 350-550, but the DOHC CYL sensor has 700-1000. Is there any way that I can bypass the CYL sensor, like connecting it to the TDC or CAM sensor? or should I get the 700-1000 ECU?
By the way, the motor is an h22a1 and the car a CRX SI, I made everything work using my stock harness with a lot of mods and this is the only thing left.
Old Feb 10, 2005 | 10:21 AM
SEEKERone's Avatar
Trialed for Treason
you are gonna need an OBD1 ECU...the #s you are talking about are resistance in OHMs.
Liar, you couldn't cut me deeper with a knife if you tried
Old Feb 10, 2005 | 01:12 PM
alri0085's Avatar
Scuderia ALRI
Do you think that the unplugged sensor is the reason for the engine to smoke?
Old Feb 10, 2005 | 01:16 PM
60-1EK's Avatar
Engineer at the source
Has the chassis been converted to OBD1? Are you trying to run an OBD1 distributor with an obd0 ecu? More information.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 10, 2005 | 03:30 PM
alri0085's Avatar
Scuderia ALRI
The harness is OBD0, I don't want the VTEC because 28 psi boost is enough. The engine runs, but it smokes like hell, the CYL sensor controls the sequential fuel injection, so all injectors are sending fuel at the same time. can't plug the CYL sensor cause of the OHMs resistance difference. I just don't want to go OBD1 just because of this sensor. I bolted the turbo kit on my car today, I'm gonna try to use a software to control the fuel/air mixture, I hope it works. If anyone knows about another alternative LMK.
Old Feb 10, 2005 | 06:07 PM
60-1EK's Avatar
Sorry man, but removing vtec because 28psi is enough.....that is just . What is your setup? What distributor are you trying to run?
You can NOT run the OBD1/2 distributor with an OBD0 ecu. You don't want to convert to OBD1 because of this sensor???? What software are you going to use to "try and control the fuel/air mixture"? More information on your setup sounds in order.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 11, 2005 | 04:25 AM
SEEKERone's Avatar
Trialed for Treason
+1 60-1EK<-----knows his stuff
Old Feb 11, 2005 | 04:25 PM
alri0085's Avatar
Scuderia ALRI
I used an OBD0 ECU and distributor, I spot welded the distributor to the head just to see if it worked, it did, but the engine runs rough, so I'm getting OBD1 ECU and distributor. My set up is a fully built H22a1 (from a RoJo shop in CA), and a complete Greddy turbo kit, it's a tight fit in a CRX but it's all there, I'm gonna wait until I buy the OBD1 stuff before trying to start it up. I got a copy of the software from the shop in CA, I had to make a harness to make it work on my OBD0 ECU. You were right about "You can NOT run the OBD1/2 distributor with an OBD0 ecu", I almost did it, but I didn't.
Old Feb 11, 2005 | 07:36 PM
60-1EK's Avatar
What software? That greddy turbo is not going to make it to 28psi, so you will need vtec I guess. Spot welded the distributor ARe you converting to an OBD1 ecu? How?
JESUS SAVES
9.69@151 Street Car
JKOBD
moldyhands
War Stories
Apr 24, 2004 05:24 AM
Cronic
Aug 6, 2003 10:16 AM
