check engine quetion???
hey hopefully someone can help me out.. the other day i swicthed all the seals on my fuel injectors...i defenitly got the right ones .. i put everything back and it was fine but then later that night my check engine light came on and also the rpms drop about 400 and i turned the car off and then turned it back on and everything is fine thats happned like every other day since last week ..just wondering if anyone knew what it could be ..
would apprieciate help..
thanks kevin
thanks kevin
find out what code it's throwing
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Originally Posted by noname
i also changed the valver cover gasket, plugs, and wires when i did that ..dont think that has nothing to do with it.......
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
check the codes- a plug not screwed in all the way wont throw a code, but an injector hanging up will. make sure there's no misfiring (hondas generally run pretty smooth so sometimes a random misfire can be hard to spot) that could cause your rpm's to be low. even if your MIL isnt on, the code should still be in the ecu.
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
BlowncobraGirl
05-19-2004 07:04 AM
gotvtec20
10-28-2002 05:50 AM
