*--Need help with swap-
Old Feb 5, 2005 | 06:11 PM
0 0 0's Avatar
Default *--Need help with swap-
i have a 96 civic dx hatch..
i swaped a b20b with gsr tranny into it everything is hooked up no leaks yet...i cant get it to run
so far it sounds like it wants to turn over but it isnt.FUEL is on the plugs and im getting spark...
im thinking i have the timing wrong or maybe the spark plug wires wrong..any thoughts or experience of this..
im running an obd2-1 ecu jumper with an obd1 ls ecu
any questions or things u need to know just ask....TIA
okay... i changed the plugs wires and timed agian and its starts.
it idles at about 2k it backfires thru the intake and the exhaust.
and when giving throttle it boggs.... i tried to switch the map and tps sensor and that didnt fix it...
and with the iacv and tps sensors unplugged it runs the same
