'93 Civic EX speedo question....
Old Feb 4, 2005 | 05:26 AM
ugly86integra's Avatar
Chuck aka Woody
check the cable first! alot of times they back out of the speed pick up in the tranny. if your sure it's in all of the way, then take it out and spin it with your fingers. the speedo should jump if it's working. (i put a makita cordless drill on the cable and it makes the speedo read about 30mph, but drill has to be in reverse though!) if the speedo doesnt work, then it's either a bad cable or a bad speedo. if it does work, then your pick up on the tranny is prob. bad.
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
Old Feb 4, 2005 | 04:04 PM
crazyhatch's Avatar
someone's been in here b4
should have a code 17 if vss is bad most of the time
Old Feb 5, 2005 | 08:39 PM
R91Si's Avatar
holy shit!!!
Old Feb 5, 2005 | 10:28 PM
Trip's Avatar
Dramatic Lemur
Definately the vss, common problem. Signs are no vtec, revs, but no speed.
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Old Feb 6, 2005 | 07:49 AM
Chuck aka Woody
Originally Posted by Cronic
The VSS on them is electrical, I believe.
i thought 93 was still mechanical. if it's not then chronic's right!
prob vss or bad connection, but if that's the case, you'll have a check engine light, and poss. drivability problems. on electronic ones, i usually take another vss and plug it in and spin it to see if the speedo works.
